Vaporizer Carburetor
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Thu Oct 01, 2020 11:25 pm
I am trying to disassemble my 1927 vaporizer. I can get all of the bolts loose, but not the vaporizer outlet tube nut. Any suggestions?
Re: Vaporizer Carburetor
Post by RajoRacer » Fri Oct 02, 2020 10:39 am
Heat & cool.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sun Oct 04, 2020 9:26 pm
I just can't get it loose. I plant to rebuild the carb so I think I will use a dremel to saw thru the sleeve nut. Any comments?
Post by Steve Jelf » Sun Oct 04, 2020 11:20 pm
What Steve said. Turn the nut red and let it cool.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Tue Oct 06, 2020 9:27 pm
Thanks to both Steves. It worked! The bronze nut on the bottom of the carb won't come off. Is it ok to use 'high" heat on it too? Probably a dumb question but I was hesitant because of it being bronze.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Tue Oct 06, 2020 9:30 pm
