26/27 patent plate
dmdeaton
Topic author - Posts: 732
- First Name: Danny
- Last Name: Deaton
26/27 patent plate
Cannot find any pics and can’t go anywhere to look. Which side of the firewall is it attached? It is so low I cannot imagine it goes behind the head on the engine side?
Re: 26/27 patent plate
Center low on the cowl panel, inside compartment, you will find two small holes punched there for the rivets to secure the patent plate.
Not commonly known, the same patent plate is used in 1925 on the inside right side of firewall. It is held on by two cowl lacing rivets.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Thanks guys, perfect!
FundyTides
- First Name: David
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Does anybody know of a source for the Canadian version of the 26-27 Patent Plate? Mine is so corroded it is unreadable.
LarryOriginal Smith wrote: ↑Sun Feb 14, 2021 11:05 amNot commonly known, the same patent plate is used in 1925 on the inside right side of firewall. It is held on by two cowl lacing rivets.
All the later original patent plates are held with 'drive screws' or else a type of std. rivet.
Have not seen 'tangs' of a split cowl type lacing rivet against the engine side of the firewall. Here are some originals, 1924, 1925 and 1926, all use the same rivet with a blunt flatten or slightly rounded rivet end, never split rivet tangs folded into the metal firewall.
Scott Kramer
- Last Name: Kramer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring,1913 touring,1921 Coupe,1923 lawnroller
David Wilson. The Canadian patent plate is available from upholsteries by Dixie, Kitchener, Ontario. Email helper@dixies.ca
They sell Model A & T parts. Good people to deal with. If you Google it , they have a website.
Scott Kramer, Woodstock, Ontario.
