26/27 patent plate
dmdeaton
First Name: Danny
Last Name: Deaton
26/27 patent plate
Post by dmdeaton » Sun Feb 14, 2021 9:08 am
Cannot find any pics and can’t go anywhere to look. Which side of the firewall is it attached? It is so low I cannot imagine it goes behind the head on the engine side?
Re: 26/27 patent plate
Post by DanTreace » Sun Feb 14, 2021 9:35 am
Center low on the cowl panel, inside compartment, you will find two small holes punched there for the rivets to secure the patent plate.
Post by Original Smith » Sun Feb 14, 2021 11:05 am
Not commonly known, the same patent plate is used in 1925 on the inside right side of firewall. It is held on by two cowl lacing rivets.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sun Feb 14, 2021 3:02 pm
Thanks guys, perfect!
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Mon Feb 15, 2021 7:26 am
Does anybody know of a source for the Canadian version of the 26-27 Patent Plate? Mine is so corroded it is unreadable.
Post by DanTreace » Mon Feb 15, 2021 9:47 am
Larry
All the later original patent plates are held with 'drive screws' or else a type of std. rivet.
Have not seen 'tangs' of a split cowl type lacing rivet against the engine side of the firewall. Here are some originals, 1924, 1925 and 1926, all use the same rivet with a blunt flatten or slightly rounded rivet end, never split rivet tangs folded into the metal firewall.
1925 patent plate.jpg (98.11 KiB) Viewed 1830 times
Scott Kramer
Last Name: Kramer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring,1913 touring,1921 Coupe,1923 lawnroller
Post by Scott Kramer » Tue Feb 16, 2021 1:27 pm
David Wilson. The Canadian patent plate is available from upholsteries by Dixie, Kitchener, Ontario. Email helper@dixies.ca
They sell Model A & T parts. Good people to deal with. If you Google it , they have a website.
Scott Kramer, Woodstock, Ontario.
