Fuel Tank Building 101 for a Speedster
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Mar 05, 2019 1:41 pm
Progress continues with other quest on this Guy's Baby!
Thought you folks would enjoy seeing how sheetmetal is formed and yes, you folks have the talent, just apply yourselves.
This is the pattern we decided to fit the custom Speedster.
A double lay out and cut using 3/4" Advantech flooring works great.
Cutting as twins and sanding as they are screwed together.[
attachment=1]IMG_1012.jpg[/attachment]
Ready to cut the sheetmetal.
More coming!
First Name: Henry
Last Name: Lee
Re: Fuel Tank Building 101 for a Speedster
Post by Henry K. Lee » Tue Mar 05, 2019 1:46 pm
Now after 2 cups of coffee we are ready to get serious.
A general mock up of what we are producing.
Tin lay out with a one inch lip.
Double check and cut.
Mark ends as there are an A and B side.
And more coming.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Mar 05, 2019 1:53 pm
Now comes the slapping or forming, this is done with light strikes combing the metal outward. Slow moment equally around is of the greatest importance in metal forming. If you don't, you will over stretch the metal which it is harder to shrink than to stretch.
A good panishing hammer is a must, maple slap hammers are your friend too.
Still more to come.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Mar 05, 2019 2:04 pm
Now we are getting at the end of the day for me. My hands give out in the cold very quick, but progress is progress.
Slapping and removing at times to put into the jaws of a shrinker, if you don't have one you can notch and fold.
Yes, I cheat!
Making a good 90 degree fold over, smoothing comes later.
This will have an outside gas gauge, no sticks required. I use old larger radiator caps/necks for the gas fill area. A lot of reproduction necks/caps are a little to bulky.
Hope You All Enjoy, More to follow as time permits!
Hank in Tin-A-See
Post by Rich Eagle » Tue Mar 05, 2019 2:05 pm
That is how I would do it. These things are so nice to see.
Thanks.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Tue Mar 05, 2019 2:30 pm
Good work Henry. I use MDF which doesn't have the voids like the chip board that can collapse on you, especially on successive steel parts. I'll be starting my tank for the mercury next month. Since it is inside the car the shape is more to fit the space than aesthetic. It will probably be aluminum.
Andy
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Mar 05, 2019 3:43 pm
I like what you are doing and appreciate your posting.
I use a “bead roller “. A very useful tool. I also have a “shrinker/stretcher”, which is really handy for some of what you are doing. These tools were not very expensive and really speed up the process Next time I do something like this I need to take some pictures.
Again thank you for your posting and keep up the good work!!
46woodduck
First Name: Thomas
Last Name: Petry
Post by 46woodduck » Tue Mar 05, 2019 6:51 pm
Always fun to watch people create parts the "old way". Beating on metal is a fun pastime.
Shane Lach
First Name: Shane
Last Name: Lach
Post by Shane Lach » Wed Mar 06, 2019 11:25 am
Thanks for the motivation to tackle my fuel tank issues!
John Warren
Last Name: Warren
Post by John Warren » Wed Mar 06, 2019 8:57 pm
Thanks Hank, Love seeing this kind of stuff.
jagiven
First Name: Jason
Last Name: Given
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
Post by jagiven » Wed Mar 06, 2019 9:15 pm
Thanks for posting, I will be watching this post closely, as we probably need to build a custom tank for the kid's speeder, and we have never done this type of work before.
What gauge steel are you using?
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Mar 07, 2019 3:37 pm
Sorry for not mentioning before, 20 gauge. Will also be showing how to seal the inside as it progresses.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Mar 08, 2019 11:20 am
Thanks Henry will be looking forward to the progress.
Last Name: Hjortnaes
Post by DHort » Fri Mar 08, 2019 11:44 am
Henry
If you could please make the next post Part 2, then we all would not have to look through this
post to see how well you have progressed.
thank you for showing us your work
dave
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Mar 08, 2019 1:02 pm
Hey, I like your way of thinking! I sure will.
All the Best,
Hank
