ID the year of this barn find ?
Burger in Spokane
Topic author - Posts: 2264
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
A friend found this. Is enough showing to make a PID ?
Fire_chief
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
Re: ID the year of this barn find ?
1923 to 25.
Slanted windshield.
Slanted windshield.
Jim Eubanks
- First Name: Jim
- Last Name: Eubanks
Interesting spare tire rack made from a touring rear mt. I had a T in Hawaii that had an identical rig.
low radiator, slant w/s. 22-23
sweet23
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
low cowl, so its a '23
Yes it does look like a early 23 low cowl.
Wonder what happened to the chassis or did I miss it. This is a genuine barn find I think. Looks like it’s been there a long time.
I missed it! The lower part of the car is covered up. You can just see the headlights. And maybe the engine.
MWalker
- First Name: Mike
- Last Name: Walker
It's a 1923.
The spare rim carrier is an accessory which was made from what appear to be mainly Ford parts with "special" brackets to mount to the running board - I believe I sold mine to Original Smith a while back.
I don't know of any "early" or "late". It's a 1923.
Burger in Spokane
- First Name: Brent
- Last Name: Burger
Thanks, super sleuths ! Good intel !
Bryce
- First Name: Bryce
- Last Name: Putnam
- * REQUIRED* Type and Year of Model Ts owned: 1925 C cab 1923 Fordor 1923 Touring 1919 Centerdoor 1915 Speedster
Late '23 it has a steel fire wall early '23 had wood fire walls
early 23 can have wood firewall. most low cowl 23's have a steel firewall slant w/s, & 1 man top. f/w is shorter & narrower. at some point, ford sold the small steel f/w as replacement for the wood f/w's. as scarse as you would expect them to be, i have seen quite a few at swapmeets over the years.
I take particular notice. my first t is one of those "rare" 23's, 40 years ago. since then i have seen many. dont seem to actually be that rare.
It's even more complicated.
How can you instantly tell the 1923 steel firewall from the 1924-25? 1924-25 has a big wiring hole above the terminal block; 1923 doesn't.
