ID the year of this barn find ?
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Mon Mar 01, 2021 2:58 am
A friend found this. Is enough showing to make a PID ?
Fire_chief
First Name: Charlie
Last Name: Gagel
Re: ID the year of this barn find ?
Post by Fire_chief » Mon Mar 01, 2021 3:53 am
1923 to 25.
Slanted windshield.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Mon Mar 01, 2021 8:17 am
Interesting spare tire rack made from a touring rear mt. I had a T in Hawaii that had an identical rig.
Post by speedytinc » Mon Mar 01, 2021 8:26 am
low radiator, slant w/s. 22-23
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Mon Mar 01, 2021 8:27 am
low cowl, so its a '23
Post by John kuehn » Mon Mar 01, 2021 8:59 am
Yes it does look like a early 23 low cowl.
Wonder what happened to the chassis or did I miss it. This is a genuine barn find I think. Looks like it’s been there a long time.
Post by John kuehn » Mon Mar 01, 2021 9:01 am
I missed it! The lower part of the car is covered up. You can just see the headlights. And maybe the engine.
MWalker
Last Name: Walker
Post by MWalker » Mon Mar 01, 2021 9:07 am
It's a 1923.
Post by RajoRacer » Mon Mar 01, 2021 10:24 am
The spare rim carrier is an accessory which was made from what appear to be mainly Ford parts with "special" brackets to mount to the running board - I believe I sold mine to Original Smith a while back.
Post by Steve Jelf » Mon Mar 01, 2021 11:55 am
I don't know of any "early" or "late". It's a 1923.
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Tue Mar 02, 2021 1:24 am
Thanks, super sleuths ! Good intel ! 👍
Bryce
First Name: Bryce
Last Name: Putnam
* REQUIRED* Type and Year of Model Ts owned: 1925 C cab 1923 Fordor 1923 Touring 1919 Centerdoor 1915 Speedster
Post by Bryce » Tue Mar 02, 2021 9:47 am
Late '23 it has a steel fire wall early '23 had wood fire walls
Post by speedytinc » Tue Mar 02, 2021 11:10 am
early 23 can have wood firewall. most low cowl 23's have a steel firewall slant w/s, & 1 man top. f/w is shorter & narrower. at some point, ford sold the small steel f/w as replacement for the wood f/w's. as scarse as you would expect them to be, i have seen quite a few at swapmeets over the years.
I take particular notice. my first t is one of those "rare" 23's, 40 years ago. since then i have seen many. dont seem to actually be that rare.
Post by Steve Jelf » Tue Mar 02, 2021 11:14 am
It's even more complicated. :)
How can you instantly tell the 1923 steel firewall from the 1924-25? 1924-25 has a big wiring hole above the terminal block; 1923 doesn't.
