Vaporizer rebuild
pron022020
First Name: Tyler
Last Name: Prondzinski
Vaporizer rebuild
Post by pron022020 » Thu Dec 23, 2021 1:47 pm
I am new to Model T's, I just bought a 27 Coupe that is mostly all original. I am trying to get it started after it has sat for some time. The vaporizer needs a rebuild; I heard a gentleman named Russ Potter is well known for his rebuilds and knowledge. Is he still rebuilding these?
Last Name: Seth
Re: Vaporizer rebuild
Post by perry kete » Thu Dec 23, 2021 2:19 pm
Welcome to the Model T world. You'll hear both pros and cons on vaporizer carbs but I have one and rebuilt it myself with parts from Snyders. If you explore the forum you will see the home page with a vendor listing and it is a great place to find parts.
pron022020
First Name: Tyler
Post by pron022020 » Thu Dec 23, 2021 5:09 pm
I am usually involved with Model A's, so I have some applicable experience with T's. The problem with my vaporizer is that I do not want to try to get the brass seats and needle assemblies out, they are stuck. There is also a hole in the casting inside on the tip of the 6279 needle. I really need somebody who is more experienced with these things than I am.
browning
First Name: David
Last Name: Kahle
* REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
Post by browning » Thu Dec 23, 2021 5:31 pm
I hesitate to suggest this but have had nothing but success with it over the years. I have restored a number of Fordson tractors and Model T autos and was stuck in the same situation with the brass being tight in the castings one time. I just happened to be talking on the phone with Duane Helman from Rosewood machine at the time and he told me to heat the carb to nearly red hot and then quickly quench it in cold water. I was appalled at his advice but he assured me that it would not blow up or crack. I tried it and found that the jets etc. could almost be removed with my fingers afterward. I have done it a half a dozen times or so over the years with the same result. Just be certain that there are no parts remaining on or in the casting that would be destroyed by the heat like aluminum or pot metal venturis, springs, etc.. Proceed carefully or disregard the information altogether. Not a recommendation -just an anecdote. Probably set the forum on fire.
Post by Mark Gregush » Thu Dec 23, 2021 9:00 pm
"Probably set the forum on fire" Not by or many others that use the same fire trick. :D
Last Name: Hjortnaes
Post by DHort » Thu Dec 23, 2021 9:41 pm
I do not like to reprint someone else's phone number.
Go to the classified section. Search for Potter. 4th post down has his phone number.
Scott C.
Last Name: Clements
Post by Scott C. » Fri Dec 24, 2021 1:11 am
Heating it up a bit and quenching it will make it easy to remove. Even with a propane or nap gas torch. It does not need to be red hot. If it does not work, just try again. I have a few vaporizer carbs, if you need some parts.
pron022020
First Name: Tyler
Post by pron022020 » Fri Dec 24, 2021 8:10 am
I see his phone number, thanks. I think I am better off finding a different casting as mine has the hole in it. It is not worth repairing when there is a fair amount of vaporizers lying around.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Fri Dec 24, 2021 12:49 pm
I have a Russ Potter rebuild from many years ago that never was installed or used. I sold that particular Model T before the carburetor was sent back and it has been hanging on my office wall ever since. I’ll sell for $150 plus postage which is a super duper price. Contact me through this forum if you are interested.
pron022020
First Name: Tyler
Post by pron022020 » Thu Dec 30, 2021 7:46 am
I ended up calling him and sending it off to him, but thanks anyways Michael.
Post by Scott_Conger » Thu Dec 30, 2021 9:09 am
Michael
that was a screaming deal
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Dec 30, 2021 9:29 am
I have a list of 3 folks who want it if Tyler did not need it so it goes to the first who contacted me.
Like others I have so much extra Model A and Model T parts I will never use it’s best to give them a good home where they will be useful. A few spare parts are necessary but hoarding does not help the hobby…..
Post by TRDxB2 » Thu Dec 30, 2021 11:20 am
Vaporizer Rebuild http://www.mtfca.com/discus/messages/82 ... 1529609068
The following diagrams are explained in the link above
