26 hogs head
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
26 hogs head
Post by RichJ » Tue Dec 28, 2021 5:11 pm
Has any one modified an regular block to mate to a 26 hogs head using the mounting ears?
Re: 26 hogs head
Post by TXGOAT2 » Tue Dec 28, 2021 5:15 pm
I haven't, and I'd speculate that the earlier blocks would not have enough iron in that area to do it.
mike catlin
Last Name: Catlin
* REQUIRED* Type and Year of Model Ts owned: 1923 depot hack
Re: 26 hogs head
Post by mike catlin » Tue Dec 28, 2021 7:22 pm
Took the holes in the 26 hogshead and threaded a plug-in.Then taped the plug to accept a 5/16 bolt so I could still use the two arms that connect to the frame rails.
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: 26 hogs head
Post by Ken Buhler » Tue Jan 04, 2022 12:35 am
That is not stopping the pan twist which causes broken crankshafts.
Work honestly
Stay true to your word
Get the job done right
Last Name: House
Re: 26 hogs head
Post by George House » Tue Jan 04, 2022 11:12 am
Ken is right. Just get those 2 accessory L brackets that fit under the crankcase with 4 bolt holes each that stabilizes the tranny cover, pan and block. I’m at the Dr. office now but someone will list the correct nomenclature.
Re: 26 hogs head
Post by TRDxB2 » Tue Jan 04, 2022 11:57 am
Oil Pan Supports
L's https://www.modeltford.com/item/3118-19.aspx
Belly https://www.modeltford.com/item/3114SPT.aspx
