Question About Fuel Line Part
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Thu Feb 10, 2022 8:06 pm
Connecting the fuel line to the sediment bulb involves the pack nut and a felt gasket. However, I see where one of the suppliers offers the option of using a neoprene gasket instead. This looks like a good option to me. Any comments?
Re: Question About Fuel Line Part
Post by DanTreace » Thu Feb 10, 2022 8:17 pm
Fuel hose neoprene, 1/4” I.d. section, is better over the felt, compresses to really seal, and can be reused.
As you can slide the section on the fuel line, easy to see the distance the fuel line engages the elbow to full depth. Then slide compression nut over the cylinder of fuel hose. Easier than packing that felt, the felt has larger I.d. and o.d.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Feb 10, 2022 8:21 pm
I have used them with 100% success….
Post by Rich Eagle » Thu Feb 10, 2022 8:28 pm
I just slice pieces of plastic tubing for seals. 1/4" id works well.
Post by RajoRacer » Thu Feb 10, 2022 8:35 pm
Please enlighten me Rich - what type of seal ?
Last Name: Juhl
Post by Oldav8tor » Thu Feb 10, 2022 8:39 pm
Felt is old school, neoprene is a superior modern alternative although purists may elect to stay with felt.
Last Name: Hjortnaes
Post by DHort » Thu Feb 10, 2022 9:21 pm
If I use felt I also add a little soap residue from the soap dish.
I would think you have to make sure it is soft if you use plastic tubing. Hard tubing will not compress as well.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Thu Feb 10, 2022 9:26 pm
The neoprene works great, have never had an issue with it.
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Fri Feb 11, 2022 9:50 pm
I have been using the felt seals ever since I got involved with Model Ts in 1967.
The felt does not leak and I have been able to reuse it.
Your milage may vary.
Bill Harper
Keene, New Hampshire
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Sat Feb 12, 2022 12:40 am
Do you use them dry, or add some kind of sealant?
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
BHarper
First Name: Bill
Last Name: Harper
Post by BHarper » Sat Feb 12, 2022 12:30 pm
Hi Miles,
In most cases I have used them dry with success.
In the past, if I suspected that the felt might need some help to seal properly, I would rub the felt with soap. Now, I reach for my tube of Aviation Fuel-Proof Lube and anoint the felt with a smidge of that.
Note of Caution:
When applying this fuel resistant material to the felt when it is on the fuel line, be mindful that a tiny fleck of the lube does not get on the open end of said fuel line and block the opening.
Fuel will not pass through the line.
Fuel will not enter the carburettor.
The engine will not start.
You will ask "What now? What happened? What did I do? This thing was running just fine."
Don't ask me how I know.
Bill Harper
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Sat Feb 12, 2022 1:01 pm
Thank you Bill. Having been an airplane guy for 40+ years, EZ-Turn brand fuel lube was what I was thinking of using. As soon as I can get the front axle assembly back under my ‘24 touring and get it off the jack stands, I have all the proper (I think) parts to replace all the plumbing from the tank and carburetor. What was there before looked more suited to plumbing water to a toilet than fuel to an engine. :roll:
Miles
Post by RajoRacer » Sat Feb 12, 2022 1:08 pm
Saturating the felt with engine oil is also an option - wipe dry after compressing onto carburetor fitting.
Post by John kuehn » Sat Feb 12, 2022 1:37 pm
Also the neoprene seal is probably most easier to get than the felt would be since it’s a more commonly used product.
But that’s my opinion.
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Sat Feb 12, 2022 3:27 pm
I saw the felt seals on Snyder’s web store, but didn’t notice the neoprene. If the felt seals don’t work I’ll try to find the neoprene seals or make some out of hose.
Miles
Post by DHort » Sat Feb 12, 2022 4:24 pm
I have done the same as Steve. Soak in oil for ease in installation. Do not install dry. If a little oil leaks out n gets in the fuel line, no harm done. The felt still gets compressed.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sat Feb 12, 2022 5:15 pm
A sightly different approach (based on what was at hand at the time) I wrapped many twists of wax coated string then tightened up - never had a leak and it has survived several removals and re-installs too.
Post by TXGOAT2 » Sat Feb 12, 2022 5:34 pm
Bees wax? Modern "wax" is often paraffin, which modern "gasoline" additives might dissolve. Real soap is probably what was used back in the day. These days, real soap would be Ivory or bright pink Zote. Lead foil "metallic" water pump packing might work well, too.
George Mills
Last Name: Mills
Post by George Mills » Sat Feb 12, 2022 5:35 pm
I had posted a similar question a while back...
I have always used the felt seals with no issues, but this last time was just a constant PITA and a drip...drip...drip...drips...everso slow but enough to gag in the house from the smell!
I thought of using 'packing twine' as my '15 had come that way years ago and still has the 'packing twine/bonnet twine' in it.
This 19 though...I tried soaping the felts....drip....drip...drip...
Then went with the neoprene...5 minutes and done...NO drips...end of discussion :D
Post by TXGOAT2 » Sat Feb 12, 2022 5:46 pm
Soap may not work with ethanol-adulterated gasoline. Any trace of water in the fuel would defeat soap.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sat Feb 12, 2022 6:11 pm
David, Are you trying to sneak in another controversial Marvel Mystery Oil thread?😊
Post by TXGOAT2 » Sat Feb 12, 2022 6:50 pm
Marvel Mystery Oil, flake graphite, and goat hair... or shag-cut Hi-Plane brand roll-your-own tobacco!
Post by RajoRacer » Sat Feb 12, 2022 7:37 pm
Side note: not all 1/4" fuel line has the same O.D. - best check the fit inside the pack nut prior to installation !
Post by DanTreace » Sat Feb 12, 2022 10:18 pm
Here's what is supplied and works every time. Use of 1/4" dia. steel brake line for the fuel line is my preference, easy to hand form the new line.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sun Feb 13, 2022 1:22 am
Good point. I don't really know what it was - an industrial grade wax string for installing NEC digital telephone exchanges in the 90's...... Probably not something most folk would have lying around ;-)
Also. I suspect we don't have the same additives that you struggle with in the US....
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Sun Feb 13, 2022 8:26 am
It may be, or similar to plumbers graphite rope or string which I have used for years with no problems. Nothing against neoprene seals, but it's what I had and it works.
Post by Original Smith » Sun Feb 13, 2022 11:08 am
I only have one late T, so if I needed to make a new gas line, I would do like Dan says, but my gas line is an original, and it works fine.
