Air Friction carburetor instructions and other literature
Topic author - Posts: 1428
- First Name: Donnie
- Last Name: Brown
I just acquired several air friction carburetor pieces of literature. Here are some scans of them ..
- First Name: Jason
- Last Name: Walters
Re: Air Friction carburetor instructions and other literature
Good stuff Donnie! Thanks for sharing this info with us!
Jason Walters
Jason Walters
- First Name: Eric
- Last Name: Hylen
- * REQUIRED* Type and Year of Model Ts owned: ‘14 Touring, ‘15 Runabout, ‘23 Runabout
Thanks, for posting this info. I’ve got an Air Friction carb on the shelf that I’ve been meaning to try out. Having the proper instructions will make setting it up easier.
- First Name: Corey
- Last Name: Walker
I bought one of those to find out what was inside. It seems to run ok but I didn’t run it for enough to check the mileage claims. The venturi slides up and down, I suppose it acts as an air valve like the flapper or balls in a Kingston.
- Last Name: Brown
Air Friction carbs are fairly common, but other than ads, I have seen very little info or items pertaining to the carbs. A few years ago I did find a watch fob, and a hat/lapel pin. Im not sure if I ever posted a photo of the watch fob and pin. So Ill post them here, just in case .....
