Air Friction carburetor instructions and other literature
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Apr 09, 2019 11:00 pm
I just acquired several air friction carburetor pieces of literature. Here are some scans of them ..
dobro1956
First Name: Donnie
Last Name: Brown
Re: Air Friction carburetor instructions and other literature
Post by dobro1956 » Tue Apr 09, 2019 11:01 pm
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Apr 09, 2019 11:02 pm
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Apr 09, 2019 11:03 pm
JWalters
First Name: Jason
Last Name: Walters
Post by JWalters » Thu Apr 11, 2019 12:42 am
Good stuff Donnie! Thanks for sharing this info with us!
Jason Walters
Eric Hylen
First Name: Eric
Last Name: Hylen
* REQUIRED* Type and Year of Model Ts owned: ‘14 Touring, ‘15 Runabout, ‘23 Runabout
Post by Eric Hylen » Fri Apr 12, 2019 10:56 am
Thanks, for posting this info. I’ve got an Air Friction carb on the shelf that I’ve been meaning to try out. Having the proper instructions will make setting it up easier.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Fri Apr 12, 2019 11:56 pm
I bought one of those to find out what was inside. It seems to run ok but I didn’t run it for enough to check the mileage claims. The venturi slides up and down, I suppose it acts as an air valve like the flapper or balls in a Kingston.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sat Apr 13, 2019 12:33 pm
Air Friction carbs are fairly common, but other than ads, I have seen very little info or items pertaining to the carbs. A few years ago I did find a watch fob, and a hat/lapel pin. Im not sure if I ever posted a photo of the watch fob and pin. So Ill post them here, just in case .....
