Wheeler-Schebler carburetor photos
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Tue Apr 12, 2022 4:09 pm
Hare two photos of the Wheeler-Schebler carburetor marked Ford. It is marked "Patent pending" - so it must be an early one,. There are later carbubetors by Schebler for a variety of auto snakes. This one was designed for the Model T Ford. Any information you might have about this early and unusual carburetor, post it here.
Joe Bell
First Name: Joe
Last Name: Bell
Re: Wheeler-Schebler carburetor photos
Post by Joe Bell » Tue Apr 12, 2022 6:07 pm
I have one also but missing the elbow, I have kept it for some bored day but that has not happened yet!
Post by Mark Gregush » Tue Apr 12, 2022 10:35 pm
Someone has changed the throttle butterfly lever. I have used them along with the later style. Good carbs. That one is in my OP about equal to Stromberg LF. The later ones, maybe the OF, they too had enricher valve setup.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Wed Apr 13, 2022 3:11 am
I certainly can't provide any info for your Ford Wheeler Darel. Interesting!
IF my info is correct, Wheeler-Scheblers were actively marketed from 1909 - 1928 and I suspect after the Marvel-Schebler merger.
Now Borg-Warner.
The Wheeler-Schebler carbs for the tractor market are very good carbs.
A 1928 tractor here has a very cherished Wheeler-Schebler A type carb. No nonsense.
My brand used them from the late teens thru 1928+.
Post by Mark Gregush » Wed Apr 13, 2022 12:05 pm
Looked at the photos again, that one looks to be the later style with the enriching valve. The earlier ones only had the 2 adjustments, no enricher setup.
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Wed Apr 13, 2022 6:45 pm
I would consider offers on this one if someone is ionterested in it.
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Apr 14, 2022 5:28 pm
I found a picture today of the Schebler manifold I had. It was NOs but also for an updraft carb. Very well made, from my memory,
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Sat Apr 16, 2022 1:33 am
I gotta post this about Tim's old photo:
That 90 degree air cleaner assembly looks like the ones I drooled over as a teenager in the J.C. Whitney catalogs!
$29.95. Meant for a model A Ford but have the the same carb bowl on the 28 International here.
