Thermosyphon - new video
Flivver
Topic author - Posts: 210
- First Name: Steven
- Last Name: Park
I'm trying something new. I've created my first Model T YouTube video. https://youtu.be/wrOl1Te5Pdo I haven't publicly released it yet. This link will allow you to view it. I am interested in your comments and suggestions. Then I'll do a final edit, and publish it. Who knows... if this goes well I might try another Model T video sometime.
Flivver, Paris Ontario CANADA
@flivverchannel
@flivverchannel
Re: Thermosyphon - new video
Nicely done...very well done, in fact
you will get a lot of comments regarding 1910+ for "no waterpump", since the waterpump was dropped so very early in production that more cars in 1909 came "without" than "with" (2500 or so "with", and 8000 or so "without")
instead of "1909" version, and "1910+" you may wish to delineate as "early" 1909 and "late" 1909
otherwise, hard to pick nits
Flivver
- Last Name: Park
Thank you Scott for the kind words of encouragement. Your suggestion to "delineate as "early" 1909 and "late" 1909" is an excellent one; I will make that change.
Thanks for taking the time to watch and reply! It is really appreciated.
@flivverchannel
@flivverchannel
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Great video! Keep it up….
Excellent. It presents the pertinent information clearly, both verbally and visibly, without a lot of extraneous blather. My only suggestion would be to raise the volume of the sound track if you can. When this is published I'll post a link to it on my website.
Flivver
- Last Name: Park
Steve, thank you for the suggestion to "raise the volume of the sound track". I will.
@flivverchannel
@flivverchannel
dykker5502
- Last Name: Deichmann
Nice short video. If you do have an infrared motion camera it could be nice to see a final scene with the engine running and the IR showing the various temperatures.
And then I will claim, that the Model A is a waterpump assisted termosyphon system. The pump helps cirkulate the water in the enginehead more than it pumps the water out of the engine to the radiator.
Finally - Ford did not drop the termosyphon system. In 1932 Ford introduced the Ford Model Y in London which had a 933 ccm termosyphon cooled engine. It was joined in 1935 by the Ford model C which had the same engine just bored up to 1172 ccm. That 1172ccm engine was almost unchanged used up to the 1960's. The last years in Germany (Ford Taunus 12M) it was with a waterpump because current styling prevented the high radiator needed for the termosyphon to work.
Ford Model Y engine bay - no waterpump
Ford Model T 1914 Touring
Flivver
- Last Name: Park
"nice to see a final scene with the engine running and the IR showing the various temperatures" I agree. But alas, I do not have an IR camera; I used interweb images for this video. Maybe another member does? A collaboration would be cool...
Interesting info on the Model Y and Model C! Nice to see the Thermosyphon had more life. The knowledge base of this group is impressive and deep.
@flivverchannel
@flivverchannel
Ford Model "Y"
Holy Cow! 8HP side valve engine and sold for about 100 Sterling...the things you learn here. This was a totally new one on me!
- Last Name: Hjortnaes
I wonder if a Y will fit in a T?
Flivver
- Last Name: Park
I have finished the Thermosyphon video and published it public on YouTube. https://youtu.be/FjC0CmzLWZ4. Thanks to everyone for previewing it and for the constructive suggestions!
@flivverchannel
@flivverchannel
