Plug In Voltage Regulator For Early Texas T Mitsubishi Alternator
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Jul 08, 2022 2:52 pm
Does anyone know the Mitsubishi or Industry replacement part number for the external plug in voltage regulator used on the early Texas T alternators marketed by the late Ralph Reeder? I know Snyders sell them for $45.00 each (6 or 12 volt, available), but I figured they probably could be bought through just about any auto parts supplier if the original application or the part number was known.
First Name: Henry
Last Name: Lee
Re: Plug In Voltage Regulator For Early Texas T Mitsubishi Alternator
Post by Henry K. Lee » Fri Jul 08, 2022 2:55 pm
They were custom made.., I have one 6 volt available for $25.00 with shipping!
Hank
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Jul 08, 2022 3:49 pm
Wow, That's shocking that they were 'custom made'. What did Mitsubishi use in them when they were in service in the original equipment vehicles? I don't need one at this point, but another T owner possibly needs a 12 volt, now.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Jul 08, 2022 4:08 pm
Hank
Hank, George Clipner is the T owner, possibly needing one. He informed me his alternator is a Hitachi, instead of a Mitsubishi. unless Mitsubishi used Hitachi alternators.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Jul 08, 2022 4:55 pm
ND, Mitsubishi, Hitachi, Toyo Electric all were contacted to the same design. The voltage plug in system to use either 6 or 12 volts was for the single wire conversion, ie, commercial applications (forklifts, etc). The other wires if not using the plug in unit is for an exciter wire and idiot light.
Hank
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Fri Jul 08, 2022 4:59 pm
I had one of those and it would only kick in at high rpms. Would it have taken a different plug in to fix that?
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Jul 08, 2022 7:26 pm
A bad ground or oily connection normal does that, just saying.
Hank
John iaccino
Last Name: Iaccino
* REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Post by John iaccino » Fri Jul 08, 2022 7:31 pm
I have one of those Hitachi alternators, had to take it off the car. The cut-in speed was so high that the alternator only started charging at about 23 mph.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Jul 08, 2022 8:37 pm
George's problem is that the alternator charges at too high a rate, blowing and burning things up. After the engine starts, within 5 seconds a fuse blows. I don't know where the fuse is located or which fuse he's talking about.
Just to clarify George's problem, he is running 12 volts; NOT 6 volts.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Fri Jul 08, 2022 8:58 pm
There is a problem with what are really 12V alternators being made to work on 6V. The field coil, being designed for 12V, cannot develop enough magnetism at the much lower field current which occurs with 6V operation. All that has been done is to modify the regulator from 14V to 7V. Hence, the poor low speed performance. To do it properly, the windings would have to also be modified.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Jul 08, 2022 9:03 pm
Nailed it on the head John!
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat Jul 09, 2022 8:14 pm
Hank, George is running 12 volts, so the 6 volt theory doesn't apply to him.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Jul 09, 2022 8:35 pm
OK..., Bad (too much) air gap between the armature and field coil will cause that on a rebuilt alternator!
Hank
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Post by Cordes_jeff » Wed Jul 13, 2022 1:00 am
I use a separate voltage regulator that was used on the 60s Chrysler. One wire from the ignition switch and another to the field terminal. They are dirt simple. An electronics minded individual can modify the solid state ones internally by changing zener diodes to obtain any cutout voltage.
Post by Jerry VanOoteghem » Wed Jul 13, 2022 12:10 pm
I have never used an alternator, but, I have had a problem where headlights, or anything else in the circuit, blows out. It was due to a shorted out ammeter. Check it out... just in case.
