Looking for this swivel
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Post by Mustang1964s » Fri Sep 16, 2022 11:27 am
Hello,
I am looking for a swivel like this.
Any idea where I can find one?
Last Name: Seth
Re: Looking for this swivel
Post by perry kete » Fri Sep 16, 2022 11:50 am
Looks like the ball joint from a riding lawnmower steering linkage
First Name: john
Last Name: karvaly
Post by speedytinc » Fri Sep 16, 2022 12:02 pm
Its carb linkage. Try napa.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Fri Sep 16, 2022 12:16 pm
Check the carb linkage that fits a K241 or similar model Kohler engine used on cub cadet garden tractors.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Sep 16, 2022 12:24 pm
If you can't find a suitable replacement, try the online catalog for McMaster-Carr hardware supply in Atlants, GA. If they don't have it; Nobody will have it. They are a wholesale supplier but sell to anyone even if you order one part, only one time. Great business to do business with. I've never had a problem with them.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Sep 16, 2022 1:46 pm
Hi Steve,
Try 1950s- 1960s ford throttle linkage I'm pretty sure there are some of those on my neighbors 57 T bird.
Craig.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Sep 16, 2022 1:57 pm
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Sep 16, 2022 2:35 pm
McMaster- Carr has a good selection of swivels depending in the rod size you need.
Post by DanTreace » Sun Sep 18, 2022 9:51 am
Lang's sells that part for the early timer rod end. Have a spare one, new in pkg. too.
Post by RajoRacer » Sun Sep 18, 2022 10:45 am
That appears to be one that comes with the TTP distributor kit - it's "modern".
Post by TRDxB2 » Sun Sep 18, 2022 12:22 pm
Following the link that Craig Leach provided above.
Jegs has many similar styles - click the link and scroll down
https://www.jegs.com/p/JEGS/JEGS-Carbur ... 3/10002/-1
There are more than these two
Jegs part on Amazon
Post by Original Smith » Sun Sep 18, 2022 1:28 pm
Looks very close to what Ford used originally. I have several NOS ones for my cars that are not for sale.
Last Name: Wrenn
Post by TWrenn » Mon Sep 19, 2022 9:33 am
This is his best bet!
Thanks for posting Dan! I was looking for them too, but sheesh couldn't find it!
Sometimes it's all in the "wording" while searching.
