Looking for this swivel
Topic author - Posts: 269
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Hello,
I am looking for a swivel like this.
Any idea where I can find one?
- First Name: Dennis
- Last Name: Seth
Re: Looking for this swivel
Looks like the ball joint from a riding lawnmower steering linkage
Its carb linkage. Try napa.
- First Name: Mack
- Last Name: Cole
Check the carb linkage that fits a K241 or similar model Kohler engine used on cub cadet garden tractors.
- First Name: Terry
- Last Name: Woods
If you can't find a suitable replacement, try the online catalog for McMaster-Carr hardware supply in Atlants, GA. If they don't have it; Nobody will have it. They are a wholesale supplier but sell to anyone even if you order one part, only one time. Great business to do business with. I've never had a problem with them.
- First Name: craig
- Last Name: leach
Hi Steve,
Try 1950s- 1960s ford throttle linkage I'm pretty sure there are some of those on my neighbors 57 T bird.
- First Name: craig
- Last Name: leach
- First Name: DAN
- Last Name: MCEACHERN
McMaster- Carr has a good selection of swivels depending in the rod size you need.
Lang's sells that part for the early timer rod end. Have a spare one, new in pkg. too.
That appears to be one that comes with the TTP distributor kit - it's "modern".
Following the link that Craig Leach provided above.
Jegs has many similar styles - click the link and scroll down
https://www.jegs.com/p/JEGS/JEGS-Carbur ... 3/10002/-1
There are more than these two --
Jegs part on Amazon
Jegs part on Amazon
Looks very close to what Ford used originally. I have several NOS ones for my cars that are not for sale.
This is his best bet!
Thanks for posting Dan! I was looking for them too, but sheesh couldn't find it!
Sometimes it's all in the "wording" while searching.
