Bridgeport Double Tube Pump Questions
Mighty1924
First Name: Rick
Last Name: Shaw
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
Post by Mighty1924 » Mon Sep 12, 2022 12:25 pm
Working on a Bridgeport Double Tube Pump.
Looking for help on the check valve at air outlet.
1. Which way does the valve go in?
2. Is there to be a spring in check valve?
3. Direction of pump leathers in tubes?
Thanks for any help
Rick.
Last Name: Humble
Board Member Since: 2006
Re: Bridgeport Double Tube Pump Questions
Post by Humblej » Mon Sep 12, 2022 1:17 pm
The direction of the pump leathers is the "cup" side is on the pressure side in the tube, the pressure helps seal it.
Last Name: Strange
Post by CudaMan » Mon Sep 12, 2022 1:27 pm
From my recollection, the directions of the pump leathers in the picture is correct. The large tube pumps air into the small tube on the down stroke and the small tube pumps air into the tire on the up stroke.
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Post by GG Gregory » Mon Sep 12, 2022 2:29 pm
Where can I buy the leathers? I have a few Bridgeports.
Last Name: Strange
Post by CudaMan » Mon Sep 12, 2022 3:06 pm
Restoration Supply carries them in various sizes.
Mighty1924
First Name: Rick
Last Name: Shaw
Post by Mighty1924 » Mon Sep 12, 2022 9:39 pm
Thanks guys for all the info.
If any one can help me out with the check valve I would appreciate.
Pump seems not to provide a good volume of air to fill tire.
And seems to leak air around top of small tube.
Rick.
Post by TXGOAT2 » Tue Sep 13, 2022 9:31 am
If the smaller tube discharges on the up stroke, it will have some sort of packing where the pump rod enters the tube head. If that leaks, you will lose air about as fast as you can pump it.
Mighty1924
First Name: Rick
Last Name: Shaw
Post by Mighty1924 » Tue Sep 13, 2022 8:28 pm
Thank you Pat for the info on the packing
I'll check it out
