Bridgeport Double Tube Pump Questions
Mighty1924
Topic author - Posts: 60
- First Name: Rick
- Last Name: Shaw
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
Working on a Bridgeport Double Tube Pump.
Looking for help on the check valve at air outlet.
1. Which way does the valve go in?
2. Is there to be a spring in check valve?
3. Direction of pump leathers in tubes?
Thanks for any help
Rick.
Thanks for any help
Rick.
- Last Name: Humble
Re: Bridgeport Double Tube Pump Questions
The direction of the pump leathers is the "cup" side is on the pressure side in the tube, the pressure helps seal it.
- Last Name: Strange
From my recollection, the directions of the pump leathers in the picture is correct. The large tube pumps air into the small tube on the down stroke and the small tube pumps air into the tire on the up stroke.
GG Gregory
- First Name: GG
- Last Name: Gregory
Where can I buy the leathers? I have a few Bridgeports.
Restoration Supply carries them in various sizes.
Mighty1924
- First Name: Rick
- Last Name: Shaw
Thanks guys for all the info.
If any one can help me out with the check valve I would appreciate.
Pump seems not to provide a good volume of air to fill tire.
And seems to leak air around top of small tube.
Rick.
Rick.
If the smaller tube discharges on the up stroke, it will have some sort of packing where the pump rod enters the tube head. If that leaks, you will lose air about as fast as you can pump it.
Mighty1924
- First Name: Rick
- Last Name: Shaw
Thank you Pat for the info on the packing
I'll check it out
I'll check it out
