Z tools
V8er
Topic author - Posts: 4
- First Name: Jon
- Last Name: Anderson
- * REQUIRED* Type and Year of Model Ts owned: 14, 15, 16, 26, 27
Z tools
I have 23 Z tools. I would like to learn their usages and their value. I also have a very nice original round gas tank with brackets and bulb for sale.
Re: Z tools
I can't set a value for you, as prices vary widely. But I can refer you to the the Model T Encyclopedia for a list of all tools and their names.
J1MGOLDEN
- Last Name: Golden
Re: Z tools
Rumor has it that there is a special set of Z Tools for the wire wheels.
I have never been able to find them.
Re: Z tools
There is a Z wire wheel rear hub puller & a long handled "T" wrench for w.w. lug nuts.
Re: Z tools
see chart for tool numbers - tool shape is under the number. You can update with Z tool #. I don't believe they are listed
V8er
- First Name: Jon
Re: Z tools
Thank you for the charts which show 3Z tools. All of the tools that I have are 5Z. Would 5Z be for Model A?
Re: Z tools
Ford updated their tool numbers - I believe some Model A tools are Z also.
V8er
- First Name: Jon
Re: Z tools
Two tools have T numbers: T 2839 and T5893. There is also 9N 17014 which is likely a tractor tool.
Re: Z tools
Re: Z tools
Early versions of some of the tools had T numbers. These same tools later were given a Z number eg the camshaft nut wrench was T2333 which became 3Z655 and then 5Z162.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Z tools
In addition to some early T tools that transitioned to 3Z tools; some 3Z tools transitioned to 5Z tools, yet all serve the same purpose.
Pep C Strebeck
- First Name: Joseph
- Last Name: M
Re: Z tools
The numbering system changed around 1920, going from the 3Z prefix to the 5Z. All 3Z tools are Model T and 5Z tools can be for the Model T or the Model A, just depends on the looking up the number to find their application (A vs. T). But don't forget about the 16Z, 24Z and 28Z tools.
http://www.mtfca.com/discus/messages/82 ... 842693.pdf
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Re: Z tools
T2839 is the wire wheel lug wrench. You could also use 5Z-161. They are both "T" shaped wrenches.
T5893 is the wrench for the spark plug and the cylinder hesd cap screws.
1922 Coupe , 1926 Touring
