Z tools
V8er
First Name: Jon
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 14, 15, 16, 26, 27
Z tools
Post by V8er » Wed Nov 16, 2022 12:41 pm
I have 23 Z tools. I would like to learn their usages and their value. I also have a very nice original round gas tank with brackets and bulb for sale.
Re: Z tools
Post by Steve Jelf » Wed Nov 16, 2022 1:11 pm
I can't set a value for you, as prices vary widely. But I can refer you to the the Model T Encyclopedia for a list of all tools and their names.
J1MGOLDEN
Last Name: Golden
Re: Z tools
Post by J1MGOLDEN » Wed Nov 16, 2022 1:30 pm
Rumor has it that there is a special set of Z Tools for the wire wheels.
I have never been able to find them.
Re: Z tools
Post by RajoRacer » Wed Nov 16, 2022 1:35 pm
There is a Z wire wheel rear hub puller & a long handled "T" wrench for w.w. lug nuts.
Re: Z tools
Post by TRDxB2 » Wed Nov 16, 2022 2:18 pm
see chart for tool numbers - tool shape is under the number. You can update with Z tool #. I don't believe they are listed
V8er
First Name: Jon
Last Name: Anderson
Re: Z tools
Post by V8er » Wed Nov 16, 2022 3:14 pm
Thank you for the charts which show 3Z tools. All of the tools that I have are 5Z. Would 5Z be for Model A?
Re: Z tools
Post by RajoRacer » Wed Nov 16, 2022 3:41 pm
Ford updated their tool numbers - I believe some Model A tools are Z also.
V8er
First Name: Jon
Last Name: Anderson
Re: Z tools
Post by V8er » Wed Nov 16, 2022 3:46 pm
Two tools have T numbers: T 2839 and T5893. There is also 9N 17014 which is likely a tractor tool.
Re: Z tools
Post by Scott_Conger » Wed Nov 16, 2022 4:27 pm
Ford Z tools.PDF
(430.21 KiB) Downloaded 111 times
Re: Z tools
Post by Allan » Wed Nov 16, 2022 5:41 pm
Early versions of some of the tools had T numbers. These same tools later were given a Z number eg the camshaft nut wrench was T2333 which became 3Z655 and then 5Z162.
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Z tools
Post by ModelTWoods » Wed Nov 16, 2022 5:57 pm
In addition to some early T tools that transitioned to 3Z tools; some 3Z tools transitioned to 5Z tools, yet all serve the same purpose.
Pep C Strebeck
First Name: Joseph
Last Name: M
Re: Z tools
Post by Pep C Strebeck » Wed Nov 16, 2022 7:55 pm
The numbering system changed around 1920, going from the 3Z prefix to the 5Z. All 3Z tools are Model T and 5Z tools can be for the Model T or the Model A, just depends on the looking up the number to find their application (A vs. T). But don't forget about the 16Z, 24Z and 28Z tools.
http://www.mtfca.com/discus/messages/82 ... 842693.pdf
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Re: Z tools
Post by Jim, Sr. » Thu Nov 17, 2022 12:00 am
T2839 is the wire wheel lug wrench. You could also use 5Z-161. They are both "T" shaped wrenches.
T5893 is the wrench for the spark plug and the cylinder hesd cap screws.
1922 Coupe , 1926 Touring
