running board brackets
dinosbunny
First Name: dino
Last Name: marinelli
Post by dinosbunny » Tue Jan 24, 2023 7:00 pm
What is the difference between 26-27running board brackets and the 19-25 brackets? Thanks
Re: running board brackets
Post by speedytinc » Tue Jan 24, 2023 7:13 pm
They are longer on both ends. When you see one loose, you will see 2 holes on each outer end about an inch apart. (3 holes total per side)
If fact, you can shorten 26-7's to work on earlier models.
dinosbunny
First Name: dino
Post by dinosbunny » Tue Jan 24, 2023 10:50 pm
Thank you much
