running board brackets
Topic author - Posts: 282
- First Name: dino
- Last Name: marinelli
What is the difference between 26-27running board brackets and the 19-25 brackets? Thanks
Re: running board brackets
They are longer on both ends. When you see one loose, you will see 2 holes on each outer end about an inch apart. (3 holes total per side)dinosbunny wrote: ↑Tue Jan 24, 2023 7:00 pmWhat is the difference between 26-27running board brackets and the 19-25 brackets? Thanks
If fact, you can shorten 26-7's to work on earlier models.
- First Name: dino
Thank you much
