TIMING TOOL
Professor Fate
Topic author - Posts: 773
- Last Name: S
TIMING TOOL
Is this tool labelled "B" sold by a retailer, or fabricated individually?
________________
**FATE**
**FATE**
Kerry
- Last Name: van Ekeren
Re: TIMING TOOL
It would have been quicker for you to check the vendors on line catalogs than post your question with photo's here. but to answer your question, Langs, $1.45
GG Gregory
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Re: TIMING TOOL
This tool only works for FORD type roller timer’s.
Professor Fate
- Last Name: S
- Last Name: Wrenn
Re: TIMING TOOL
Just use the "9:30-3:30" crank pin method and you'll be fine. PM me if you're not familiar with it and I'll describe it to you. Gimme your cell number even and I will call you.
Re: TIMING TOOL
It's pretty easy. No special tool needed.
https://dauntlessgeezer.com/DG97.html
Re: TIMING TOOL
Different strokes for different folks. Steve’s method works pretty good.
The tool shown is real similar to the one that could be homemade in Tinkerin Tips years ago.
- Last Name: Juhl
Re: TIMING TOOL
New Day - great timer....just sayin'
Professor Fate
- Last Name: S
Re: TIMING TOOL
I'm a tool geek. I like to collect stuff.
I made something similar out if a paint stick using my other cars timer as a model. I'll grab a mix for you all when I go out to the shop shortly
________________
**FATE**
**FATE**
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: TIMING TOOL
Beware, as others have stated, the Ford Service Manual timer gage the vendors sell is ONLY reliable when using a Ford timer and a Ford roller. Other timers have different internals, brushes, or different rollers.
- Last Name: Wrenn
Re: TIMING TOOL
That's the "9:30-3:30" method I plan to talk to him about.John kuehn wrote: ↑Fri May 26, 2023 9:11 amDifferent strokes for different folks. Steve’s method works pretty good.
Nv Bob
- First Name: Bob
- Last Name: Middleton
Re: TIMING TOOL
This tool only works on stock roller timer
Best way is Crank ratchet pin is parallel to the ground this puts piston TDC half the time set and run and fine tune as needed
Been Here Before
- First Name: George John
- Last Name: Drobnock
Re: TIMING TOOL
As fate would have it --
Running a New day Timer...this may be helpful:
https://modeltfordfix.com/repairing-a-new-day-timer/
Putting the hobby back another 60 years (c).
Professor Fate
- Last Name: S
Re: TIMING TOOL
Here's a pic of my homemade timing tool from 2 yrs ago. It's a wood paint stick. I had never seen the picture in the manual until the other day. I used my other T to make this one pictured. Manual dimension is 2.5 inches from center of each hole. Mine is 2.75 in.
I get repeated hot starts and my car starts easy. Sunday I'll look at 330-930 pun location. Thanks to all for your help.
________________
**FATE**
**FATE**
