TIMING TOOL
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
TIMING TOOL
Post by Professor Fate » Fri May 26, 2023 2:52 am
Is this tool labelled "B" sold by a retailer, or fabricated individually?
________________
**FATE**
Kerry
Last Name: van Ekeren
Re: TIMING TOOL
Post by Kerry » Fri May 26, 2023 3:06 am
It would have been quicker for you to check the vendors on line catalogs than post your question with photo's here. but to answer your question, Langs, $1.45
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Re: TIMING TOOL
Post by GG Gregory » Fri May 26, 2023 5:45 am
This tool only works for FORD type roller timer’s.
Professor Fate
Last Name: S
Re: TIMING TOOL
Post by Professor Fate » Fri May 26, 2023 5:46 am
I'm running a New Day timer.
________________
**FATE**
Last Name: Wrenn
Re: TIMING TOOL
Post by TWrenn » Fri May 26, 2023 6:38 am
Just use the "9:30-3:30" crank pin method and you'll be fine. PM me if you're not familiar with it and I'll describe it to you. Gimme your cell number even and I will call you.
Re: TIMING TOOL
Post by Steve Jelf » Fri May 26, 2023 9:02 am
It's pretty easy. No special tool needed.
https://dauntlessgeezer.com/DG97.html
Re: TIMING TOOL
Post by John kuehn » Fri May 26, 2023 9:11 am
Different strokes for different folks. Steve’s method works pretty good.
The tool shown is real similar to the one that could be homemade in Tinkerin Tips years ago.
Last Name: Juhl
Re: TIMING TOOL
Post by Oldav8tor » Fri May 26, 2023 9:23 am
New Day - great timer....just sayin' :D
Professor Fate
Last Name: S
Re: TIMING TOOL
Post by Professor Fate » Fri May 26, 2023 9:25 am
I'm a tool geek. I like to collect stuff.
I made something similar out if a paint stick using my other cars timer as a model. I'll grab a mix for you all when I go out to the shop shortly
________________
**FATE**
Last Name: Humble
Board Member Since: 2006
Re: TIMING TOOL
Post by Humblej » Fri May 26, 2023 9:39 am
Beware, as others have stated, the Ford Service Manual timer gage the vendors sell is ONLY reliable when using a Ford timer and a Ford roller. Other timers have different internals, brushes, or different rollers.
Last Name: Wrenn
Re: TIMING TOOL
Post by TWrenn » Fri May 26, 2023 10:32 am
That's the "9:30-3:30" method I plan to talk to him about.
Nv Bob
First Name: Bob
Last Name: Middleton
Re: TIMING TOOL
Post by Nv Bob » Fri May 26, 2023 10:41 am
This tool only works on stock roller timer
Best way is Crank ratchet pin is parallel to the ground this puts piston TDC half the time set and run and fine tune as needed
Been Here Before
First Name: George John
Last Name: Drobnock
Re: TIMING TOOL
Post by Been Here Before » Fri May 26, 2023 12:57 pm
As fate would have it --
Running a New day Timer...this may be helpful:
https://modeltfordfix.com/repairing-a-new-day-timer/
Putting the hobby back another 60 years (c).
Professor Fate
Last Name: S
Re: TIMING TOOL
Post by Professor Fate » Fri May 26, 2023 10:00 pm
Here's a pic of my homemade timing tool from 2 yrs ago. It's a wood paint stick. I had never seen the picture in the manual until the other day. I used my other T to make this one pictured. Manual dimension is 2.5 inches from center of each hole. Mine is 2.75 in.
I get repeated hot starts and my car starts easy. Sunday I'll look at 330-930 pun location. Thanks to all for your help.
________________
**FATE**
