Locating mounting holes.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sat May 27, 2023 10:45 am
I’m checking the alignment of my firewall to cowl support mounting holes to the cowl itself. Eventually a piece of gasket if will go under the cowl support wood.
This is for my 22 Centerdoor. Some of the support wood is original. Other parts are a kit from a different style of car, since no cowl wood is made for this car.
William L Vanderburg
1922 Center Door Sedan
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: Locating mounting holes.
Post by Ken Buhler » Sat May 27, 2023 11:09 am
Brackets are intended to hold parts that are already mated , not as a starting point to build from.
Work honestly
Stay true to your word
Get the job done right
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Sat May 27, 2023 11:29 am
I’m not building anything. I’m just making sure my mounting holes are aligned. The car will be assembled in a specific order on its frame. I do not have anyplace to build a body on a flat floor, and then raise that body into place.
