I’m checking the alignment of my firewall to cowl support mounting holes to the cowl itself.  Eventually a piece of gasket if will go under the cowl support wood.
This is for my 22 Centerdoor.  Some of the support wood is original. Other parts are a kit from a different style of car, since no cowl wood is made for this car.
							Locating mounting holes.
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
				Ken Buhler
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Re: Locating mounting holes.
Brackets are intended to hold parts that are already mated , not as a starting point to build from.
									Work honestly
Stay true to your word
Get the job done right
Will_Vanderburg
I’m not building anything. I’m just making sure my mounting holes are aligned. The car will be assembled in a specific order on its frame. I do not have anyplace to build a body on a flat floor, and then raise that body into place.Ken Buhler wrote: ↑Sat May 27, 2023 11:09 amBrackets are intended to hold parts that are already mated , not as a starting point to build from.
William L Vanderburg
1922 Center Door Sedan
