Model T accessory??
les_rens
First Name: Les
Last Name: Rens
* REQUIRED* Type and Year of Model Ts owned: 26 open, 25 tudor, many parts cars.
Model T accessory??
Post by les_rens » Tue May 21, 2019 11:59 am
This came in a parts lot of Model T stuff. Is it some sort of optional part or accessory??
Ruxstel24
Last Name: Hanlon
Re: Model T accessory??
Post by Ruxstel24 » Tue May 21, 2019 12:07 pm
That's an early Sirius XM antenna... :lol:
Last Name: House
Post by George House » Tue May 21, 2019 12:32 pm
Ha ! Dave, you’re too funny....All seriousness aside - It’s a steering stabilizer. The bottom part between the 2 spring circles (on the runningboard) fastened to the rod bolted to the 2 spindle arms and the 2 “”antenna”” simply were forced onto the backside of the front axle.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue May 21, 2019 12:42 pm
LMAO Dave!!!
Hank
Post by Steve Jelf » Tue May 21, 2019 1:13 pm
It's a groove maker. It digs grooves in your tie rod. :D
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Tue May 21, 2019 1:35 pm
Steve is absolutely correct. This is a cheap temporary fix for a loose front end. These were often used during the Depression when people often couldn't afford a good front end rebuild.
Keith
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Tue May 21, 2019 1:46 pm
Absolutely right Steve. These work very well as evidenced by the very precise grooves cut into the tie rod on our 26 Touring when we bought it.
DLodge
First Name: Dick
Last Name: Lodge
Post by DLodge » Tue May 21, 2019 2:56 pm
C'mon, Dave, be sirius! :D
