Model T accessory??
Topic author - Posts: 23
- First Name: Les
- Last Name: Rens
- * REQUIRED* Type and Year of Model Ts owned: 26 open, 25 tudor, many parts cars.
Model T accessory??
This came in a parts lot of Model T stuff. Is it some sort of optional part or accessory??
- Last Name: Hanlon
Re: Model T accessory??
That's an early Sirius XM antenna...
- Last Name: House
Ha ! Dave, you’re too funny....All seriousness aside - It’s a steering stabilizer. The bottom part between the 2 spring circles (on the runningboard) fastened to the rod bolted to the 2 spindle arms and the 2 “”antenna”” simply were forced onto the backside of the front axle.
- First Name: Henry
- Last Name: Lee
LMAO Dave!!!
Hank
Hank
It's a groove maker. It digs grooves in your tie rod.
- First Name: Keith
- Last Name: Gumbinger
Steve is absolutely correct. This is a cheap temporary fix for a loose front end. These were often used during the Depression when people often couldn't afford a good front end rebuild.
Keith
Keith
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Absolutely right Steve. These work very well as evidenced by the very precise grooves cut into the tie rod on our 26 Touring when we bought it.
- First Name: Dick
- Last Name: Lodge
C'mon, Dave, be sirius!
