Cleaning NH Carburetor
ABoer
Topic author - Posts: 237
- First Name: Anthonie
- Last Name: Boer
What is the best way to clean the inside canals of a NH Carburetor .
Thanks for your answer .
Toon
Toon
M.Sinclair
- First Name: Matthew
- Last Name: Sinclair
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1919 Runabout
Re: Cleaning NH Carburetor
Ive heard that you should have them vaporblasted usually motorcycle shops can do that.
AndyClary
- First Name: Andrew
- Last Name: Clary
There are brass plugs at the end of each passage. Remove the plugs and soak the carb in carb cleaner. I use an ultrasonic cleaner. Use a wire through the passages to ensure there’s nothing in there. You can plug the passages back up with soft brass like brazing rod. Vapor blasting will make it pretty but won’t clean the passages which are really the important part.
Andy
Andy
- Last Name: Patrick
I have always had good luck with the spray type, Xylene based aerosol cleaners with the red small tube that allows for high pressure spraying into the passageways. “Gumout” is a good example but there are all types of brands which work equally well. Jim Patrick
I have soaked in acetone overnight. Then blow out all passages with compressed air. Usually no need to remove plugs. If the idle still doesn't work satisfactorily, then the plugs will need to be removed and do as Andy says above.
Here are complete disassembly, cleaning & reassembly instructions - step by step with pictures etc
https://modeltfordfix.com/rebuilding-th ... el-t-ford/
Don't forget to get one of Scott Conger's Float-Valves
This one covers a few extra things to do https://www.mtfca.com/discus/messages/4 ... 1402151664
- Last Name: Hatch
Order the club carburetor book. Everything you need.
