Late 1912-Early 1913 KW Ignition Coil-Need helP
Ron Patterson
Post by Ron Patterson » Fri Aug 09, 2024 1:08 pm
I am building a KW Coilbox & Coils for a Late 1912 to Early 1913 Model T.
This coilbox & coils was only used by Ford for 6 months when transition to the Ford/KW co-produced metal top coils became available.
I have everything I need with the exception of one point adjuster thumbnut.
This thumbnut is unique in that the threads are 6-32 as opposed to the 10-32 used in later coils.
I have enclosed some photos so you can see what I am seeking and where it was used.
If anyone has one of these spare or has a early KW coil (regardless if it has an open secondary winding or not) they would sell me please let me know.
Ron Patterson
Re: Late 1912-Early 1913 KW Ignition Coil-Need helP
Post by RajoRacer » Fri Aug 09, 2024 1:16 pm
I'll check Ron - I ended up with most of Otis Clinton's brass goodies !
Ron Patterson
Post by Ron Patterson » Fri Aug 09, 2024 5:41 pm
Just tyo clarify, in addition to being a 6-32 threaded hole the top of the knurled thumbnut is 500.
Ron P.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Aug 09, 2024 9:45 pm
No Gots :(
Respectfully Submitted,
Be_Zero_Be
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sat Aug 10, 2024 7:04 am
Give brent a call just handed him one thursday.
Post by Original Smith » Sun Aug 11, 2024 2:10 pm
I'll have to check someday. I have a couple of dozen '13 coils, and none are for sale!
Ron Patterson
Post by Ron Patterson » Sun Aug 11, 2024 6:15 pm
Thanks for the feedback.
I found what I needed, one thumbnut for a 1912-1913 KW Williams design coil.
Ron P.
