Good evening. The subject pretty much sums it up. I've got a 1913 rear axle with very worn parts, including the spider and spider gear bushings (yes, bushings). Would the guts (differential) from an early 1920's rear axle fit into the 1913 housing without any fitment issues?
Thank you!
20's differential in 1913 rear axle housings?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: 20's differential in 1913 rear axle housings?
yes, everything will fit the same as the earlier parts.
MMorse
Topic author - Posts: 12
- First Name: Mike
- Last Name: Morse
- * REQUIRED* Type and Year of Model Ts owned: 1924 tudor sedan
Okay, thanks. That’s what I understood but was second guessing myself. I appreciate your help.
- Last Name: Hatch
That is the beauty of a Model T. Most mechanical parts are interchangeable between the years. It was planned that way.
