Rear wheel nut torque
Topic author - Posts: 2326
- Last Name: Juhl
I know that Henry didn't specify a torque value for rear wheel nuts other than "really tight." I've done some research and found 70 ft-lbs, 120 ft-lbs and 200 ft-lbs suggested in early posts. Anyone care to chip in with your recommendation?
JP_noonan
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Re: Rear wheel nut torque
Tim, i usually start out at a minimum of 75 lbs, then tighten up to the next nut notch which might end up at 100 lbs.+ or-. Opinions may vary, but 200 lbs. seems very excessive to me.
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Isn't that one of the places where you're supposed to turn it until just before it breaks?
Mindless Automaton
- First Name: Kep
- Last Name: Kerensky
- * REQUIRED* Type and Year of Model Ts owned: 23 truck, 26 bug
- Board Member Since: 2011
I use 70ft/lb. The reproduction nuts are made of cheese & don't handle much more than 90. Old orig' ones are tougher but mostly all gone. Anything too tough & the axle threads would strip right off so... cheese nuts it is!
JohnH
- Last Name: Hunter
- Board Member Since: 2002
I presume we're talking about axle nuts, and not the nuts used to secure the rims to wheel. In that case, I start at 110 ft. lbs. and hope a castellation lines up with the hole before I get to 140 ft. lbs. Original and repro nuts and axles seem fine with that. After the car has been driven for a while, I recheck the nut is tight enough - if driven around with it loose, the taper of the axle and hub, as well as the key-way will wear.
I have seen where the axle nuts were done up with an ordinary shifting spanner hand tight; the assumption was the key was all that was necessary to keep everything in position. The result was the most elongated keyway I have seen.
I've had previous cars that I brought home and pulled the wheels for a check-up only to find the rear nuts were barely beyond snug. Thank God for cotter pins! I use a 2' breaker bar on my socket and yank and tug until my back and/or shoulder hurts like heck and the cotter hole is exposed. Havent lost a wheel yet! Just sayin'
Scottio
lol. Thats a great one. Tighten it till a shoulder or back goes pop then install the cotter pin.
TFan
- First Name: Jim
- Last Name: Riedy
I always heard "tighten till failure then 1/4 turn" . Jim
- Last Name: Strange
I use JP's method - 70 ft-lbs, then pull more as needed to get the castellations to line up.
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Here is the wrench that Ford supplied for the job when our Model T's were new.
This is an original 5Z-248 rear axle Ford wrench. It has a 21 inch long heavy pipe handle.
I have never used it, because i'm afraid I would strip the axle or nut.
1922 Coupe , 1926 Touring
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
So, if my calculations are anywhere near correct, using this wrench, a person would need to push with just over 45 lb. of pressure on the end of the wrench, to get 70 lb/ft of torque on the axle nut. Seems logical. But, if a person really leaned on the wrench, with his body weight, you could get well over 100 lb/ft torque. I'm still confused. I think I will shoot for the 70 - 100 lb/ft zone and to the next castlelation for the cotter pin. Sure don't want that nut loose.
Thanks for the photo. I didn't know Ford had a special wrench for the axle nuts.
