replace closed cab with C Cab
clee2
First Name: Clint
Last Name: Lee
Post by clee2 » Sun Sep 28, 2025 2:02 pm
Is is possible to replace the closed cab of a TT with a C-Cab? Just trying to find out the logistics of it.
Last Name: Humble
Board Member Since: 2006
Re: replace closed cab with C Cab
Post by Humblej » Sun Sep 28, 2025 2:05 pm
Yes you can.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sun Sep 28, 2025 5:07 pm
Here are the options:
C Cab (well maybe a 'square C :-) ) No Cab (Roadster) and Closed Cab (Colonial), :
Last Name: House
Post by George House » Sun Sep 28, 2025 6:58 pm
Yes; it’s perfectly interchangeable. The 4 Ford TT cab mounting brackets on the frame are the same for a Ford TT enclosed cab and Ford TT C cab.
clee2
First Name: Clint
Last Name: Lee
Post by clee2 » Fri Oct 03, 2025 1:12 pm
Thanks for the info
Post by RajoRacer » Fri Oct 03, 2025 2:16 pm
O.T. - kinda - George - love your Lang's October calendar photo !
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Fri Oct 03, 2025 2:52 pm
Because your TT has a 1925-27 closed cab you are good to go and change out the Ford closed cab for a Ford C cab. In 1925 when Ford came out with the closed cab they changed the front cab mounting bracket so that either type cab will mound to the bracket. But if the TT is a 1924 chassis the front cab mounting bracket is smaller and is only designed to mount the C cab.
Last Name: House
Post by George House » Sat Oct 04, 2025 3:18 am
Awww… thanks for the recognition Steve. But I can’t find my calendar now. :oops:
