Model T clutch drive drum / basket
greenacres36
First Name: Brian
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Post by greenacres36 » Fri Nov 10, 2023 12:28 pm
I am manufacturing these parts. They are made from billet 1045 steel. Easy to balance, and come much better balanced than the originals. More durable than the original material is.
$200 plus shipping.
Re: Model T clutch drive drum / basket
Post by speedytinc » Sun Nov 12, 2023 11:35 am
Consider offering some with a .003-.004" undersize hole.
That would allow the use of many center shafts that have lost their press fit from being run loose.
Post by Mark Gregush » Sun Nov 12, 2023 11:45 am
That is a great idea! That is up there with only suppling the upper driveshaft bushing in standard size with no room to ream for undersize driveshaft. :)
Post by Jerry VanOoteghem » Mon Nov 13, 2023 12:02 pm
Are these heat treated?
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Mon Nov 13, 2023 1:59 pm
Did you make them exactly to the FORD print? There is much more to correctly making these than meets the eye…
