I am manufacturing these parts. They are made from billet 1045 steel. Easy to balance, and come much better balanced than the originals. More durable than the original material is.
$200 plus shipping.
Model T clutch drive drum / basket
greenacres36
Topic author - Posts: 164
- First Name: Brian
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Re: Model T clutch drive drum / basket
Consider offering some with a .003-.004" undersize hole.
That would allow the use of many center shafts that have lost their press fit from being run loose.
That is a great idea! That is up there with only suppling the upper driveshaft bushing in standard size with no room to ream for undersize driveshaft.speedytinc wrote: ↑Sun Nov 12, 2023 11:35 amConsider offering some with a .003-.004" undersize hole.
Are these heat treated?
Adam
- First Name: Adam
- Last Name: Doleshal
Did you make them exactly to the FORD print? There is much more to correctly making these than meets the eye…
