WTB Engine Stand Adapter
su8pack1
Topic author - Posts: 98
- Last Name: Kelly
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Looking for an engine stand adapter like the venders used to sell. All out of stock for years.
modeltbarn
- First Name: Gary
- Last Name: London
Re: WTB Engine Stand Adapter
Hi Dan. I have one I made as a second that functionally is the same. It has been drilled for the bolts to mount at the water jacket and has the pins that align into the pan holes. I never drilled it for the engine stand because I never mounted it on my stand (I didn't need to hang two engines at the same time).
I can send a picture tomorrow if you are interested. You can have it for $30 plus actual postage. It can fit in a flat rate padded envelope. I'm attaching my contact info; please send an email and I'll get a picture to you.
su8pack1
- Last Name: Kelly
This is the type I'd like to get.
- Attachments
- A-6005-ADP.jpg (28.59 KiB) Viewed 2098 times
- First Name: craig
- Last Name: leach
Hi Dan,
I'd check out Gary's the price is great. But for others that missed out this is what I came up with for my cheap budget. Using a $30 swap meet
engine stand & a little ingenuity I came up with this. It's cheap & you can move the center of gravity ( engine only to engine & trans ) without
taking the engine off the stand. It will not work with every engine stand & requires some drilling & welding but not much work that you can't
find someone to help with if you can't do those yourself. Craig.
su8pack1
- Last Name: Kelly
I made one I'm using now, I need to adjust the bottom angle iron above the pan, not perfect but does the job. Just looking for the basic one as I want to start another engine I have at the same time. I could make another, but the one piece unit would be nice to have.
modeltbarn
- First Name: Gary
- Last Name: London
Engine stands come with the round tube / plate assembly and four arms to bolt up to pretty much any engine block. The adapter plate the vendors used to sell mounted to this, or fixed adapters; all you had to do was drill 4 holes for the arms to bolt to, or if your tube/plate assembly had fixed holes you’d drill the T adapter plate to match. The problem with one having a fixed tube is that not all angine stands have the same diameter tube, so an adapter plate has a fixed tube attached it only works with stands that accept that size tube. That’s why an adapter plate that bolts to the tube is more versatile, and why I built mine that way.
If you’re interested let me know, if not that’s fine too.
su8pack1
- Last Name: Kelly
modelbarn, definitely interested, email sent. Thanks.
Lil Teezy
- First Name: Chris
- Last Name: Levi
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring 1927 roadster
The Berts Model A (Englewood, Co.) catalog on line shows them In stock. Chris, in Boulder
Bill Mullins
- First Name: Bill
- Last Name: Mullins
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
su8pack1
- Last Name: Kelly
I'm looking for one like the venders sold that will fit both the Model T and the Model A like the one pictured above. Thanks for your offer though.
