WTB Engine Stand Adapter
su8pack1
Last Name: Kelly
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by su8pack1 » Fri Dec 29, 2023 9:52 am
Looking for an engine stand adapter like the venders used to sell. All out of stock for years.
modeltbarn
First Name: Gary
Last Name: London
Re: WTB Engine Stand Adapter
Post by modeltbarn » Fri Dec 29, 2023 7:27 pm
Hi Dan. I have one I made as a second that functionally is the same. It has been drilled for the bolts to mount at the water jacket and has the pins that align into the pan holes. I never drilled it for the engine stand because I never mounted it on my stand (I didn't need to hang two engines at the same time).
I can send a picture tomorrow if you are interested. You can have it for $30 plus actual postage. It can fit in a flat rate padded envelope. I'm attaching my contact info; please send an email and I'll get a picture to you.
su8pack1
Last Name: Kelly
Post by su8pack1 » Fri Dec 29, 2023 8:04 pm
This is the type I'd like to get.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Dec 29, 2023 11:15 pm
Hi Dan,
I'd check out Gary's the price is great. But for others that missed out this is what I came up with for my cheap budget. Using a $30 swap meet
engine stand & a little ingenuity I came up with this. It's cheap & you can move the center of gravity ( engine only to engine & trans ) without
taking the engine off the stand. It will not work with every engine stand & requires some drilling & welding but not much work that you can't
find someone to help with if you can't do those yourself.
su8pack1
Last Name: Kelly
Post by su8pack1 » Sat Dec 30, 2023 12:24 am
I made one I'm using now, I need to adjust the bottom angle iron above the pan, not perfect but does the job. Just looking for the basic one as I want to start another engine I have at the same time. I could make another, but the one piece unit would be nice to have.
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Sat Dec 30, 2023 12:46 am
Engine stands come with the round tube / plate assembly and four arms to bolt up to pretty much any engine block. The adapter plate the vendors used to sell mounted to this, or fixed adapters; all you had to do was drill 4 holes for the arms to bolt to, or if your tube/plate assembly had fixed holes you’d drill the T adapter plate to match. The problem with one having a fixed tube is that not all angine stands have the same diameter tube, so an adapter plate has a fixed tube attached it only works with stands that accept that size tube. That’s why an adapter plate that bolts to the tube is more versatile, and why I built mine that way.
If you’re interested let me know, if not that’s fine too.
su8pack1
Last Name: Kelly
Post by su8pack1 » Sat Dec 30, 2023 10:44 am
modelbarn, definitely interested, email sent. Thanks.
Lil Teezy
First Name: Chris
Last Name: Levi
* REQUIRED* Type and Year of Model Ts owned: 1926 touring 1927 roadster
Post by Lil Teezy » Sat Dec 30, 2023 11:05 am
The Berts Model A (Englewood, Co.) catalog on line shows them In stock. Chris, in Boulder
su8pack1
Last Name: Kelly
Post by su8pack1 » Sat Dec 30, 2023 11:57 am
I called them last week and not in stock, Lang's and other venders don't show them out of stock on their web site also, but don't have then.
Bill Mullins
First Name: Bill
Last Name: Mullins
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by Bill Mullins » Sat Dec 30, 2023 10:22 pm
Is this what your looking for. $40.00 plus shipping
su8pack1
Last Name: Kelly
Post by su8pack1 » Sun Dec 31, 2023 9:00 am
I'm looking for one like the venders sold that will fit both the Model T and the Model A like the one pictured above. Thanks for your offer though.
