Wanted Running board mounted spare holder.
Chris Haynes
Topic author - Posts: 400
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
I am looking for the spare holder that mounted on the cowl and running board on the drivers side.
Kevin Pharis
- Last Name: Pharis
Re: Wanted Running board mounted spare holder.
There was a fella here a while back that was threatening to reproduce this bracket that mounts to the windshield bracket. Not sure where the project went, but would selfishly like to see these available
Looks like it mounted to front lamp bracket
https://www.mtfca.com/discus/messages/1 ... 43892.html
The smaller one made by DEC. AUTO. PRODUCES. CO.DECATUR. ILL. U.S.A.
The larger one is marked MFRD BY LP HALLADAY CO DECATUR ILL USA -- --
I have the cowl piece - you'd have to fashion the open hoop for the running board.
elliott1936
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
I hope I'm not steeping on Steve's toes, I also have a cast iron bracket that uses the cowl light bolt to mount to the cowl. It will need a bottom mount to carry the tire on the running board. This item is posted here in the adds.
Wkndead
- Last Name: Mercier
- * REQUIRED* Type and Year of Model Ts owned: 1912 touring, 1922 six post delivery, other
If no luck let me know as I know I have one in the barn. It's the long version like the first picture with an extra casted loop to add a padlock.
rickd
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
You don't mention the year of car you have; this is a spare mount that attaches to the windshield stanchion bolts on a 24-5. It has the remnants of a decal on the top and a part number on the underside. Not trying to sell it, just wanted to share a later style of spare mount for your search.
Belliott3
- First Name: Bill
- * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Hey Richard, if the upper part in your barn is still available and no one has spoken for it, I’d be interested: I have the bottom carrier but nothing to secure the top. I sent you a PM
