Sold (pending payment): Used rear axle ring & pinion set
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Jan 01, 2025 2:02 pm
Sold (pending payment). Here is a ring & pinion set that came out of the same rear end. The axle wasn’t noisy but had a little excessive thrust washer clearance on the left side that accounts for the moderate wear that can be seen on the ring gear. The pinion gear is in very good condition. This is an excellent opportunity to save some major money versus buying a new set. $125. Includes shipping inside the USA. Email if you want it. Please do not post here or pm. Thanks.
CDooREDW
First Name: Ron
Last Name: Wenzel
* REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: For Sale: Used rear axle ring & pinion set
Post by CDooREDW » Wed Jan 01, 2025 3:01 pm
Hi, Adam. Sent you an email. I’ll take them, pls.
Tnx,
Ron
