Sold (pending payment). Here is a ring & pinion set that came out of the same rear end. The axle wasn’t noisy but had a little excessive thrust washer clearance on the left side that accounts for the moderate wear that can be seen on the ring gear. The pinion gear is in very good condition. This is an excellent opportunity to save some major money versus buying a new set. $125. Includes shipping inside the USA. Email if you want it. Please do not post here or pm. Thanks.
Sold (pending payment): Used rear axle ring & pinion set
Adam
Topic author - Posts: 1604
- First Name: Adam
- Last Name: Doleshal
CDooREDW
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: For Sale: Used rear axle ring & pinion set
Hi, Adam. Sent you an email. I’ll take them, pls.
Tnx,
Ron
Tnx,
Ron
