WTB: Magneto drive coupling, ie 2 flanges with flexible disc between for tapered shaft magneto such as Bosch DU4
rendo
First Name: JOHN
Last Name: RENDEMONTI
* REQUIRED* Type and Year of Model Ts owned: 1925 two door sedan
Post by rendo » Thu Jan 16, 2025 5:58 pm
WTB: Magneto drive coupling, ie 2 flanges with flexible disc between, for a tapered shaft magneto such as a Bosch DU4, etc.
Re: WTB: Magneto drive unit, ie 2 flanges with flexible disc between
Post by Mark Gregush » Thu Jan 16, 2025 10:52 pm
Are you looking for whole drive or just the couplings? If just the couplings might want to update your listing on what drive unit and magneto you are using. Also, if either are straight or tapered shafts.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Jan 17, 2025 1:09 pm
A simpler option to manufacture is the MATCO cross drive style coupling. This was basically a pair of 1” diameter hubs that mount to each side, and a short length of fabric reinforced rubber hose clamped between. Very simple and low profile. Will try to dig up a pic…
babychadwick
First Name: Chad
Last Name: Azevedo
Re: WTB: Magneto drive coupling, ie 2 flanges with flexible disc between for tapered shaft magneto such as Bosch DU4
Post by babychadwick » Tue Feb 18, 2025 8:29 am
Would a lovejoy coupling work?
