WTB: Magneto drive coupling, ie 2 flanges with flexible disc between for tapered shaft magneto such as Bosch DU4
				rendo
- First Name: JOHN
- Last Name: RENDEMONTI
- * REQUIRED* Type and Year of Model Ts owned: 1925 two door sedan
WTB: Magneto drive coupling, ie 2 flanges with flexible disc between, for a tapered shaft magneto such as a Bosch DU4, etc.
Re: WTB: Magneto drive unit, ie 2 flanges with flexible disc between
Are you looking for whole drive or just the couplings? If just the couplings might want to update your listing on what drive unit and magneto you are using. Also, if either are straight or tapered shafts.
				Kevin Pharis
- Last Name: Pharis
A simpler option to manufacture is the MATCO cross drive style coupling.  This was basically a pair of 1” diameter hubs that mount to each side, and a short length of fabric reinforced rubber hose clamped between.  Very simple and low profile.  Will try to dig up a pic…
babychadwick
- First Name: Chad
- Last Name: Azevedo
Re: WTB: Magneto drive coupling, ie 2 flanges with flexible disc between for tapered shaft magneto such as Bosch DU4
Would a lovejoy coupling work?
