I am just going to have a pair made. Cast Iron Sunderlin type Rocky Mnt Brake Drum
NorthSouth
Last Name: California
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
Post by NorthSouth » Fri Jul 18, 2025 3:14 pm
Would anyone have “one” cast iron Rocky Mountain Break Drum. I need to match the one pictured below.
Thanks,
Steve
Los Angeles
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are. -Ed Archer
Sarikatime
Last Name: Seress
Re: Need “one” Cast Iron Rocky Mnt Brake Drum
Post by Sarikatime » Fri Jul 18, 2025 4:07 pm
Steve, Those are, I believe, two different brake drums stuck together. Call the Rocky Mountain brake drum manufacturers, phone and information available in the Vintage Ford magazin advertisement. Also, maybe call Dave at Chaffins garage, he got me new linings when my brakes got hot and caught on fire.
Post by RajoRacer » Fri Jul 18, 2025 4:51 pm
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are !
NorthSouth
Post by NorthSouth » Sun Jul 20, 2025 3:54 pm
Back to the Top
NorthSouth
Re: Need “one” Cast Iron Sunderlin type Rocky Mnt Brake Drum
Post by NorthSouth » Fri Aug 01, 2025 2:10 pm
I am still looking for one of these drums.
NorthSouth
Post by NorthSouth » Wed Aug 06, 2025 4:08 pm
Would anyone have an alternative idea on how to get break drums that will work with and original set of large drum Rocky Mountain Brakes?
First Name: john
Last Name: karvaly
Post by speedytinc » Wed Aug 06, 2025 4:11 pm
Check with the current mfg. Get dimensions. I believe the drums are the same size, just not the preferred cast iron.
Buy a pair.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Aug 07, 2025 1:43 am
Hi Steve,
The RM drums are advertised as 11 3/4" and the one in your pic looks to be 12" ( the larger drum) I have no idea the width of the cast drums.
Have you giver any thought to having a metal fab shop roll a ring the correct width of 1/8" or 3/16" cold or hot rolled steel that can be heated to
fit over a RM drum so it shrinks to fit tight then welded & machined to the needed specs to match? At least you would not have to worry that it
was worn out?
Craig
NorthSouth
Post by NorthSouth » Thu Aug 14, 2025 1:35 pm
Maybe the manufacturer’s name is spelled “Sunderland”. I still need one of these break drums to match the one pictured above.
NorthSouth
Re: Need “one” Cast Iron Sunderlin Sunderland type Rocky Mnt Brake Drum
Post by NorthSouth » Sun Aug 17, 2025 8:52 pm
I need one of these.
Post by Original Smith » Mon Aug 18, 2025 10:49 am
Sunderlin is correct.
NorthSouth
Post by NorthSouth » Thu Aug 21, 2025 12:27 am
I am giving up finding this break drum.
Having two new ones cast.
Re: I am just going to have a pair made. Cast Iron Sunderlin type Rocky Mnt Brake Drum
Post by Original Smith » Thu Aug 21, 2025 12:30 pm
Is the company casting your new ones in California?
First Name: john
Last Name: karvaly
Post by speedytinc » Thu Aug 21, 2025 12:38 pm
Would it be worth while to have extras made? They are superior to the pressed steel.
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Thu Aug 21, 2025 6:44 pm
Steve, check with Cattail Foundry. They are Amish, call leave a number and he will get back to you. He has done a couple of parts for me and does excellent work. He is used to working with original parts as patterns. You can find information on the web even a short news article about the work they do.
Good luck,
Kevin
JSteele
First Name: John P.
Last Name: Steele
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by JSteele » Sat Aug 23, 2025 12:11 pm
Steve I would be interested in buying a set.
John
Last Name: Gregush
Post by Mark Gregush » Sat Aug 23, 2025 12:47 pm
Why not have them cast like the originals, with the inner brake drum as part of the casting or is that your plan?
Post by Original Smith » Sat Aug 23, 2025 5:31 pm
The originals were not cast. They were steel. A factory inside drum was riveted to the drum.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sat Aug 23, 2025 7:36 pm
To clarify for everyone- the reproduction brakes made by Jack Sutherland (prior to the version currently being manufactured ) were supplied with a one piece cast iron brake drum that incorporated an integral small brake drum in a single casting along with the larger diameter drum. This was Jack's way of duplicating the original two piece riveted assembly that Larry is referring to above.
Last Name: Gregush
Post by Mark Gregush » Mon Aug 25, 2025 9:53 am
Thanks Dan and Larry. Looking the top photo I got the impression that was how they were made original, a one piece casting.
