I am just going to have a pair made. Cast Iron Sunderlin type Rocky Mnt Brake Drum
Topic author - Posts: 608
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up, 1924 PACO Bodied Speedster
Would anyone have “one” cast iron Rocky Mountain Break Drum. I need to match the one pictured below.
Thanks,
Steve
Los Angeles
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are. -Ed Archer
Thanks,
Steve
Los Angeles
- Last Name: Seress
Re: Need “one” Cast Iron Rocky Mnt Brake Drum
Steve, Those are, I believe, two different brake drums stuck together. Call the Rocky Mountain brake drum manufacturers, phone and information available in the Vintage Ford magazin advertisement. Also, maybe call Dave at Chaffins garage, he got me new linings when my brakes got hot and caught on fire.
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are !
Back to the Top
Re: Need “one” Cast Iron Sunderlin type Rocky Mnt Brake Drum
I am still looking for one of these drums.
Would anyone have an alternative idea on how to get break drums that will work with and original set of large drum Rocky Mountain Brakes?
Check with the current mfg. Get dimensions. I believe the drums are the same size, just not the preferred cast iron.
Buy a pair.
Buy a pair.
- First Name: craig
- Last Name: leach
Hi Steve,
The RM drums are advertised as 11 3/4" and the one in your pic looks to be 12" ( the larger drum) I have no idea the width of the cast drums.
Have you giver any thought to having a metal fab shop roll a ring the correct width of 1/8" or 3/16" cold or hot rolled steel that can be heated to
fit over a RM drum so it shrinks to fit tight then welded & machined to the needed specs to match? At least you would not have to worry that it
was worn out?
Craig
was worn out?
Craig
Maybe the manufacturer’s name is spelled “Sunderland”. I still need one of these break drums to match the one pictured above.
Re: Need “one” Cast Iron Sunderlin Sunderland type Rocky Mnt Brake Drum
I need one of these.
Sunderlin is correct.
I am giving up finding this break drum.
Having two new ones cast.
Re: I am just going to have a pair made. Cast Iron Sunderlin type Rocky Mnt Brake Drum
Is the company casting your new ones in California?
Would it be worth while to have extras made? They are superior to the pressed steel.
- Last Name: Fielding
Steve, check with Cattail Foundry. They are Amish, call leave a number and he will get back to you. He has done a couple of parts for me and does excellent work. He is used to working with original parts as patterns. You can find information on the web even a short news article about the work they do.
Good luck,
Kevin
Good luck,
Kevin
- First Name: John P.
- Last Name: Steele
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Steve I would be interested in buying a set.
John
John
Why not have them cast like the originals, with the inner brake drum as part of the casting or is that your plan?
The originals were not cast. They were steel. A factory inside drum was riveted to the drum.
- First Name: DAN
- Last Name: MCEACHERN
To clarify for everyone- the reproduction brakes made by Jack Sutherland (prior to the version currently being manufactured ) were supplied with a one piece cast iron brake drum that incorporated an integral small brake drum in a single casting along with the larger diameter drum. This was Jack's way of duplicating the original two piece riveted assembly that Larry is referring to above.
Thanks Dan and Larry. Looking the top photo I got the impression that was how they were made original, a one piece casting.
