WTB 5 lug wire wheel spare carrier
Wolffydmc16
First Name: Clint
Last Name: W
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Wolffydmc16 » Wed Aug 13, 2025 3:04 pm
Looking for a spare tire carrier for the back of my touring after I converted to steel wheels. Haven't found any local at the swaps. Not looking for something perfect, I'm on a budget. Please let me know what you have. Thanks
1921Touring "Tootsie T" my first Model T
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Re: WTB 5 lug wire wheel spare carrier
Post by TFan » Wed Aug 13, 2025 3:56 pm
If you already have a Ford spare carrier all you should have to do is unbolt the "Y" and the wires should be able to bolt onto the triangle part that is hidden beneath. Hope I explained it clearly. Jim
Ps. I added a couple pics of the one from my roadster the stock ones I would think are about the same as far as the 'Y'.
Post by speedytinc » Wed Aug 13, 2025 4:06 pm
You need to be clearer.
What kind of carrier do you have now & what kind of "steel" wheel are you hoping to mount.
Last Name: Hatch
Post by Dan Hatch » Wed Aug 13, 2025 4:21 pm
I think there is a Service Bulletin that explains all this.
Wolffydmc16
First Name: Clint
Last Name: W
Post by Wolffydmc16 » Thu Aug 14, 2025 12:48 pm
I'm looking for the 26/27 gooseneck style that attaches to the rear spring clamps, ive converted to early A wheels.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Thu Aug 14, 2025 12:59 pm
I have one that needs some work that's can be budget friendly ill send you a email with some pics
Wolffydmc16
First Name: Clint
Last Name: W
Post by Wolffydmc16 » Thu Aug 14, 2025 1:01 pm
This is what I have
Amd what I'm looking for
Post by speedytinc » Thu Aug 14, 2025 1:44 pm
Model A wheels are a different bolt pattern. A goose neck carrier will need some modification.
Wolffydmc16
First Name: Clint
Last Name: W
Post by Wolffydmc16 » Thu Aug 14, 2025 3:11 pm
That's no problem to change the pattern
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Tue Aug 19, 2025 3:39 pm
Sent a email several days ago with pics for you
Last Name: Hjortnaes
Post by DHort » Thu Aug 21, 2025 1:10 am
Just wondering if a Model A gooseneck would work. There should be a lot of them around if Model A's used goosenecks. Otherwise I know Model A cars had wheel wells in the front fender. Have you considered that method?
I see you have another carrier at the present time. You will have to lift the body to get that out.
You might also need the longer brackets on the rear spring to get a gooseneck to fit. That is what I had to do. I think I still have a set if you are looking for some.
Wolffydmc16
First Name: Clint
Last Name: W
Post by Wolffydmc16 » Thu Aug 21, 2025 2:20 pm
All the A tire mounts I've seen are very stubby. Just a few inches.
I didn't know this current mount style would need the body to be lifted to remove, sounds fun.
My car has nice paint so I'm not looking to cut a well in the fender to fit one up there.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Thu Aug 21, 2025 2:45 pm
That tire mount you have is probably riveted to the frame 3 rivets each side if you lucky its bolted
