Re-babbitted ball cap ( 4th. main )
Gene_French
Topic author - Posts: 1098
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Model T ball cap re-babbitted and bored to Standard or you specified diameter ...price is $50.00 + exchange + $19.30 priority flat rate mail in lower 48 states or actual postage outside this area or INTERNATIONAL ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
- First Name: Gene
- Last Name: French
Re: Re-babbitted ball cap ( 4th. main )
to the top again ...thanks MTFCA
Nv Bob
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Gene
I been digging have two so far and befor I send them got one more pile to dig on
Nv bob
Nv bob
Gene_French
- First Name: Gene
- Last Name: French
Bob:
thanks for looking ... if you can send a batch that cuts down on the mailing cost per item ... always an optimist Gene French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Tim D
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Do you buy bad ones for cores?
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ... thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Shrshot
- First Name: Kent
- Last Name: Palazzo
- Board Member Since: 2024
Gene I need to replace my 4th main ball cap. Where should I take the measurement to determine if I need std. or .002 under? I pulled the rear axle assembly, and have quite a bit of oil in the torque tube leaking from the ball cap. Have to repair/rebuild rear diff as spool housing is cracked and leaking grease also. Oh the joys....
Gene_French
- First Name: Gene
- Last Name: French
Kent:
you will measure the clutch plate ... probably with a dial or vernier caliper ... with the ball cap removed you will reach into the hogs head with the caliper jaws and measure the outside diameter of the clutch plate tailshaft ...access is difficult with anything except a long jaw caliper or the removal of the hogshead ...
Shrshot
- First Name: Kent
Thanks Gene, I will get ahold of you when I get the ball cap out and shaft measured.
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ...Thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
