Re-babbitted ball cap ( 4th. main )
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Fri Mar 24, 2023 11:03 am
Model T ball cap re-babbitted and bored to Standard or you specified diameter ...price is $50.00 + exchange + $19.30 priority flat rate mail in lower 48 states or actual postage outside this area or INTERNATIONAL ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
First Name: Gene
Last Name: French
Re: Re-babbitted ball cap ( 4th. main )
Post by Gene_French » Sun Apr 02, 2023 11:02 am
to the top again ...thanks MTFCA
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Sun Apr 02, 2023 2:24 pm
Gene
I been digging have two so far and befor I send them got one more pile to dig on
Nv bob
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Apr 06, 2023 11:41 am
Bob:
thanks for looking ... if you can send a batch that cuts down on the mailing cost per item ... always an optimist Gene French
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat May 13, 2023 9:40 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jul 02, 2023 10:10 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Oct 14, 2023 3:16 pm
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Post by Tim D » Sat Oct 14, 2023 3:24 pm
Do you buy bad ones for cores?
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Dec 01, 2023 10:21 pm
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Jan 18, 2024 10:03 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Mar 28, 2024 10:06 am
to the top again ... thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Aug 04, 2024 9:12 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Aug 29, 2024 9:25 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jan 04, 2025 10:59 am
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Sun Jan 05, 2025 12:50 am
Gene I need to replace my 4th main ball cap. Where should I take the measurement to determine if I need std. or .002 under? I pulled the rear axle assembly, and have quite a bit of oil in the torque tube leaking from the ball cap. Have to repair/rebuild rear diff as spool housing is cracked and leaking grease also. Oh the joys....
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 05, 2025 10:41 am
Kent:
you will measure the clutch plate ... probably with a dial or vernier caliper ... with the ball cap removed you will reach into the hogs head with the caliper jaws and measure the outside diameter of the clutch plate tailshaft ...access is difficult with anything except a long jaw caliper or the removal of the hogshead ...
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Mon Jan 06, 2025 1:16 pm
Thanks Gene, I will get ahold of you when I get the ball cap out and shaft measured.
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 26, 2025 10:57 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Apr 18, 2025 8:43 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 30, 2025 10:02 am
to the top again ...Thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jul 05, 2025 8:35 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Nov 08, 2025 8:34 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Mon Dec 29, 2025 8:58 am
