Wanted, speedo cable parts.
Post by Allan » Mon Jul 31, 2023 9:01 am
I need 16" of speedo cable links like those on the bottom of the photo. The top links are standard Stewart fare.
I need links like the bottom ones for a Corbin sppeedo drive. The connecting links are just like the Stewart ones, but rather than the two hooked ends being on the same plane, they are at 90 degrees to each other. The intermediate links are castings, the annular rings around them acting as bearings within the casing.
