Ruckstell 3:25 Ring Gear, Bill Everett
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Post by Bill Everett » Mon Mar 11, 2024 4:15 pm
I'd like to buy a new Ring Gear for the Ruckstell currently under construction.
Does anyone have a 3:25 they'd part with?
3:63 is too low, and 3:1 is too high.
If you have a 3:25 you'd let go, please send me a few pictures at bill.everett@epickett.com, and how much $$ you'd like for it.
Thank you.
Bill Everett
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Ruckstell 3:25 Ring Gear, Bill Everett
Post by BE_ZERO_BE » Mon Mar 11, 2024 4:29 pm
For a 3.25 gear ratio, a 12 tooth pinion and 39 tooth ring gear are required.
Respectfully Submitted,
Be_Zero_Be
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Mon Mar 11, 2024 7:40 pm
I believe, as Bob said, you would need the 12 tooth pinion and a recessed ring gear made for the 3:1 high speed gears. Then you would need to add space under the ring gear to raise it to the proper clearance with the 12 tooth pinion. When I did it, I had to add a 1/16 inch, or .0625 shim. Stacking shims increases the chance of sheared ring gear bolts.
Post by speedytinc » Mon Mar 11, 2024 8:56 pm
I confirm all that.
I made my shim out of 6061-T6
A stack of steel shims is more likely to move & shear the bolts.
Post by Mark Gregush » Mon Mar 11, 2024 10:30 pm
Bill you might use the pencil thing over to the right and add Wanted to the title and remove your name. :)
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue Mar 12, 2024 10:00 am
If a 3.33 would satisfy your needs, a 12 - 40 should be doable.
Art Mirtes
Post by speedytinc » Tue Mar 12, 2024 2:07 pm
Art Mirtes
A stock ring gear from an 11-40 set wont work with a 12T pinion.
A 12T pinion is a larger diameter than the 11 T, but smaller than a 13T.
This is the reason the ring gear(39 or 40 for a 3-1 set) needs some shimming.
I thought It would be possible To use the stock 40T gear with a 12T pinion in a Rux by machining that aprox. .062" off the carrier(bell) & shortening the ring gear bolts. This would eliminate the danger of a shim & bolts shearing.
This is my plan if I have a shearing failure in my T. So far, so good.
