WTB, Fan Shaft grease cup
Post by Original Smith » Mon Aug 05, 2024 12:15 pm
These parts are not listed separately in the parts book. I want to stipulate the entire assembly is solid brass and screws onto the fan shaft. Don't want a reproduction. Need the grease cup and the nut it screws onto.
QuestQuencher
First Name: Avery
Last Name: Jones
* REQUIRED* Type and Year of Model Ts owned: 1923 Ford Model T Runabout
Re: WTB, Fan Shaft grease cup
Post by QuestQuencher » Mon Aug 05, 2024 9:55 pm
Just clarify that you need the whole assembly in solid brass, including the grease cup and the nut, and that you're looking for original parts, not reproductions. That should help narrow down your search.
Post by RajoRacer » Mon Aug 05, 2024 10:22 pm
Can't say I've ever seen a brass nut one Larry - I've got original steel ones.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Tue Aug 06, 2024 10:57 am
Never seen a brass one either only steel grease cups
Post by TRDxB2 » Tue Aug 06, 2024 12:25 pm
Understand that your looking for originals not repros.
Just to confirm: when you say you want the entire assembly ... then... Need the grease cup & the nut it screws into. Did you mean the assembly (cup with nut) that screws onto the fan shaft end.
